PostgreSQL Issue
Hi. Just downloaded the newest version of Daz Studio (4.12.0.86) via the Install Manager (1.4.0.17), both of which are the 64-bit version. I went to log in (Connect -> Login) and got the following error message:
- Connecting to DAZ 3D (sic) requires a valid connection to a PostgreSQL CMS database. A database connection could not be established. Check for the following potential causes:
- PostgreSQL application files are not installed, (sic) or are not installed correctly. (sic)
- Anti-Virus (sic) software has quarantined PostgreSQL application files.
- Firewall software/hardware is blocking the connection to PostgreSQL CMS.
- The current user does not have permissions to execute PostgreSQL application files.
#1, No new anti-virus updates today.
#2, No new firewall updates today.
#3, I'm an administrator.
I was using the program earlier today, was logged in, and had done two renders. The program was working just fine until I updated five minutes ago when I ran DAZ Install Manager. Now I can't log in. Just so you know.
I assume you get no error on starting DS, just on Connect? Check that PostgreSQL really is installed (it should be, but just as a double-check).
https://helpdaz.zendesk.com/hc/en-us/articles/207812393-PostgreSQL-Connection-Error-and-No-Smart-Content
