Doing squats
I'm not sure if it's possible but is there a simple way to lock the legs or change the pivot maybe so that when I select the hips and drag it down using the arrow to bend the knees and start doing squats instead of going through the floor?
Have you tried pinning the feet against translation? This is done using the universal tool, clicking on the feet, then clicking on the pin to the top right of the selected node box. You can pin against rotation too, which may be appropriate depending on the movement you want.
Then when you move the figure, the feet should stay in position, while the legs move. If you take it too far, strange things will happen as the legs go beyond limits, but before then it should work.
It's perfect. Thank you very much
