Monster hunter monsters poser?
Hello!
I search Monster hunter's monsters for Daz studio. Did you know where can I find them? I want to make Monster hunter annimation but withaout monsters...
Thenk you so much!
Hello!
Thenk you so much!
Is there a particular monster you wanted?
Sasquatch is here:
http://www.daz3d.com/sasquatch
Some other Monster Hunter monsters are simply large versions of the animal and could be simulated by scaling models such as these larger:
Alligator:
http://www.daz3d.com/crocodilia-1-alligator-and-caiman
and Python:
http://www.daz3d.com/morphing-python
Charlie
I want Rathalos, Brachydios, Jaggi and Dire Miralis. It's possible to get them?
Maybe you could use some of these or modify their color or texture:
Wyvern:
http://www.daz3d.com/wyvern-2-0
or http://www.daz3d.com/raw-wyvern
Dragon:
http://www.daz3d.com/sales-promotions/millennium-subdragon
http://www.daz3d.com/dragon-clutch
http://www.daz3d.com/dragon-clutch-2
http://www.daz3d.com/moorland-dragon-bundle
Also do a store search for 'dragon' There is a large variety available that might be useable:
http://www.daz3d.com/catalogsearch/result/index/?cat=1072&ea;_a=&ea;_bc=&ea_c=Creatures&ea_path=-dragon&q=dragon&x=10&y=2
Thenks but I want the true rathalos (I try to make it myself but no success...)
I have Wivern and some dragon but not them all
Have you seen these? They seem to be for game models but they are all I know about. I'm not sure if you could import them into Poser or DAZ Studio.
http://steamcommunity.com/sharedfiles/filedetails/?id=105072495
http://facepunch.com/showthread.php?t=1077566
From what I understand, it is possible to take models from Garry's Mod and get them into Daz/Poser, but it's extremely difficult.
I did manage to find a gallery on deviantart with several monsters from Monster Hunter (Rathalos included) for Xnalara. If you download that and the models from his gallery, they can be exported from Xnalara/XPS and imported into Poser.
http://iireii.deviantart.com/gallery/31527089
Thenks nut how can I download them please?
For Gary's model
Click on the subscribe button and follow the instructions and links)
For the FacePunch model
click on the mediafire download link in the post:
For the ones in the Deviant art gallery (Posted by lface8)
click on the picture then click on the word 'link' near the end of the first description (by IIReII) and follow it to the creator's website. For example, clicking on the Rathalos picture brings up the following page with description:
http://iireii.deviantart.com/art/MH3-Rathalos-333410297
If you need them, download links for XPS may be found in the middle of the page (bottom of description just above comments) here:
http://xnalaraitalia.deviantart.com/journal/XPS-10-9-4-Wardrobe-Edition-349764705
For Gary's model
Thenk you so much! But how I instal them? x)
Maybe he or someone else can help you more with the conversion
As previously noted. download links for XPS may be found in the middle of the page (bottom of description just above comments) here:
Charlie
But in the download there are .pose, .png etc... I have to convert this?
To install the models into Xnalara/XPS, drag and drop the folder into the data folder. Start Xnalara up, go to "file" add model and select the model you want. When that's loaded, you can load a pose by going to "file" load pose, then browse to where you extracted the previous folder containing the model you want. Then go to Modify, export scene as .obj. If it asks you to export with textures, check that box and hit ok and save it to a new folder. Then open Poser or Daz and import that OBJ file you just saved. Not sure if Poser has import presets such as ".blend" or whatever, but if importing into Daz, select Bryce as the import preset. All the textures should load automatically.
Thenks! But my XNALara dosen't work. He stop running all the time whaen I lunsh it. (I have Windiws 8.1)
Ok it's good XNALAra work now... But... THe rathalos can't be moved... I can't move the leg, the mouth, nothing... If I put a pose, it is white... Please help :')
You have to apply the pose in Xnalara. As far as I know, once imported into Daz or Poser, they can't be posed.
So I can't make annimation? Damn :'(
You'd have to rig it in DS first...
Hum... I don't understand sorry ^^'
To make something posable, it needs to have a 'skeleton'. The process of making the skin and 'bones' move together is called rigging.
Daz Studio has the tools, included, to be able to do this, but it is much easier to do with a model that has a bit of set up done to it with rigging it for DS or Poser in mind, as there are some differences in the process from rigging game models. I haven't been able to convert the models, because I haven't found a converter that runs on my system, so I'm not sure what all would need to be done to rig it.
