Will Long hair for V4 work on Genesis or Genesis 2 Females?
I was reading and it said there is some distortion of long hair when it goes threw autofit. I am wondering if long V4 hair can be used with Genesis and/or Genesis 2. And what I would need to do/buy to make it work. If it can work at all. Advice about shorter hair or any advice about using V4 hair on Genesis of Genesis 2 females is welcome. I have not bought any V4 hair because I don't know what can be made to work and what can't. I need advice before I make any bad purchases. I've bugged the sales department too much already. I'm trying to research better before I buy. I am very interested in Valea's hair models as I love long hair and I like many of the models for V4 as well as models for Genesis and Genesis 2. Also Advice about what will happen if I try to fit Genesis to Genesis 2 wouldn't hurt to know.
Sometimes Autofit works, sometimes it doesn't. If not just put the hair in position manually, then parent it to the head.
Hi @RitaCeleste
I don't know if you've read @Scott-Livingston's hair tutorial. If you haven't, there is a lot of helpful information on working with hair including fitting V4 hair to Genesis. I've used the same techniques outlined for fitting "older" hair to G2 as well.
Hope this helps. Hair tutorial: http://www.daz3d.com/forums/discussion/17656
Trish
Thanks! That helps loads. I got it bookmarked so I don't loose it.
RuntimeDNA has a very good Dragonbraid hair for V4 bundle which works well with V6. It comes as a base skull cap which easily autofits to V6's head. There are then several hair/braid props which can be parented (not autofited) to the base skull cap. It looks quite spectacular.
