How to save an all maps for skin preset
Hi all,
I customized some of the settings of an already existing skin (Kimm for Babina).
My question would be how can I save them all under one thing so I can load all the settings in one (Ideally I could also add that preset to the Kimm package so it is together with the skin).
Thanks
  • FSMCDesignsFSMCDesigns Posts: 12,844
    Save as a material preset
  • alex86firealex86fire Posts: 1,130
    edited February 2020
    Oo, wow, once the selection pop-up up it was clear it was what I needed, thanks! Not sure why I didn't try I as I was in between that and shader preset.
    Any idea how I can add it to the Kimm package?
    Post edited by alex86fire on
  • jardinejardine Posts: 1,215
    just navigate to the kimm directory in your library when you're saving the preset.
    probably People/Genesis 8 Female/Characters/Kimm/Materials/ .
    j
    Note that this doesn't work if you installed with Connect — DAZ|Studio considers the Connect folders to be protected and will not let you save in there. If you installed manually or with DIM, you can navigate to the folder in the Content Library (NOT Smart Content) pane and click the "+" button at the bottom to add whichever save file type you want.
    Also note that if you want to save the materials for eyelashes, eyebrows, or anything else parented to the Genesis figure, use Hierarchical Material Preset instead of just Material Preset.
