Can't find my injected FBMs for V3 in D/S 4.6 Pro, Shaping tab, Editor task
ModernWizardModernWizard Posts: 904
Hi all. Back in the saddle again after not messing around with digital models for a few years. I'm resurrecting one of my faves, V3, but having trouble trying to get to her morphs in D/S Pro 4.6. I load her up and inject a whole bunch of morphs. Then I go to the Posing/Shaping menu, Shaping tab, Editor task.
I make sure that I have the whole figure selected because I want to dial in FBMs. But there are no collapsible menus of morphs. [See screenshot.] I know that the FBMs have injected correctly, as I can see them if I click on a body segment, but I don't know why they aren't showing up when I select the whole figure. Can anyone help with my probably extremely obvious question? Thank you.
--MW
  • fixmypcmikefixmypcmike Posts: 19,692
    As V3 is an older figure, the morphs aren't configured to show in the Posing and Shaping panes -- you'll need to use the Parameters pane.
  • ModernWizardModernWizard Posts: 904
    Mike, I appreciate your prompt reply. I will take note of this when using my old content. Thanks again.
    --MW
