G8F - How do you prevent the shoulder from changing/morphing breast shape?
When posing G8F, if you move her shoulder around, it also moves the breast around. How do you prevent that from happening?
  • The breast changes because that is, more or less, what happens in reality (which is why a lot of pin-up poses have their arms raised). A lot of it is due to rlation ships between morphs and transforms, so you could click the chain icon on the sliders for Pectoral bones' rotations to break their links as a first step.
  • FlortaleFlortale Posts: 611
    Hmm, how do I find these pectoral bones?  I see Left & Right Pectoral under the scene view for Genesis 8 Female.  Under the parameters, I put pectoral in the filter, but nothing came up even with Show Hidden on.  I'm guessing this is part of another system of G8F?
  • QuixotryQuixotry Posts: 919
    If you select one of the pectoral bones in the scene tab, you'll be able to see the controls for it in the parameters tab. :)
    I have the Left Pectoral selected on Genesis 8 Female under the Scene Tab.  Under the parameters tab, I can't seem to find a chain icon that controls the sliders for Left Pectoral?
  • Each slider should have a chain icon on it, to the right alongside the Heart (for favourites) and gear (for settings) icons.
    I got it now.
    1. On Genesis 8 Female, select Right Pectoral by either left clicking on that breast or choosing it from the scene tab.
    2. Under Parameters goto transforms, then select the controller Side-Side, then click the small chain icon in the upper right hand corner of Side-Side's rectangular window. That prevents the Right Collar from moving the breast from side to side.  Unchecking that chain icon prevents any other body part from affecting the Side-Side controller on Right Pectoral.
    Thanks for the help everyone. Hopefully this helps others.
    Wait a second, something still not right.
    On the Right Pectoral, I have Up-Down and Side-Side unchained, but when I Bend the Right Collar all the way by a negative value, it still changes the morph shape of the Right Pectoral Breast.  It doesn't affect it as much, but it still changes the shape.
