Genesis left tight bend problem
Hello.
Like title says i have this problem with genesis left tight bend looking bad.
Is there enyway to fix this?
Thanks in advance.
Post edited by coren on
Hello.
Thanks in advance.
I've got the same problem (had it for months now). I've searched high-and-low for a solution and have come up empty. I know others have had the problem (from other posts) and it seems they found a solution, but didn't post it. I'm guessing most people don't have this problem and, therefore, can't help (kind of impossible to solve a problem one can't produce :).
The only solutions (work-arounds) I've come up with are to use clothing, place an arm over top, change camera angles, or use Gen4.
If I find a proper solution, I'll post it... Please do the same.
Cheers!
