I need simple instructions SOLVED
TrishTrish Posts: 2,625
edited January 2014 in New Users
I can't work with this the way it is....I want this mover deal closer to the figure....How do I make that happen.....Thanks Trish
Post edited by Trish on
  • SimonJMSimonJM Posts: 6,073
    Someone has written a 'reset centre' script which I hvae, as yet, not manged to get to work!
    What I do, and it can be a little painful, especially with such a lrage offset as you have there, is to use the Joint Editor (from the Tools menu) and search out the little red and green 3-d arrows that denote the points of rotation and movement, and move them over to the figure.
  • TrishTrish Posts: 2,625
    edited January 2014
    simon: when I went into the tools menu and choose the joint editor ......she lit up all kinds of colors but the mover deal vanished.......I am not doing this right.....I think maybe I will just try to pose her myself instead of trying the pose for the pool
    322 x 286 - 23K
    Ok I have ran into a number of my items where I need the mover deal closer to the object ...so I really do need to learn how to do this...I haven't gotten very far on my own with it.....
    That is exactly what you will see! If you swing the viewport back to where the movement icons were in the scene you should see two, tiny, little icons, one red, one green. They may, or may not be close together! ;)
    Cool Thanks Simon I got it.......LOL
    355 x 296 - 32K
    It's a pain when that happens! Some items load with move and rotate points away from the actual item, and it happens to others when poses are applied. There must (should?) be a simple way of resetting them.
