Application open error
Dear Sirs, I am getting constantly the same error trying to open the application. The error image has been sent to you in the attachment. What do I need to do to open the application without any problems?
I would be glad if you help me in detail. From now; thanks a lot for your help,
Post edited by Chohole on
That doesn't look like opening the application, you are loading content there. The problem is that the files are not installed correctly - it would be ebst to isntall using Install Manager or Connect, which will also give you the metadata allowing the files to show in other views, but you could just take everything from /My Daz 3D Library/Power Catamaran/Content/ and place directly it in the /My Daz 3D Library/ folder.
