dforce problem
Hi,
Can you tell me how to correct this "slight" distortion when I do the simulation.
The skirt is rigged.
It has material zones for the waistband which I set the dynamics 0
The other zones are set t0 85.
Any help is appreciated.
Cheerio
lululee
  • OdaaOdaa Posts: 1,548
    Looks like front seam is not welded in your modeling program. Also you may have made the female character herself into a dynamic surface by mistake, or is the distortion on purpose?
  • lululee1lululee1 Posts: 343
    Hi Odaa,
    Thanks so much for you quick assesment.
    You were correct. Somehow I put the deforce on G8.
    Much appreciation for your valuable info. You saved me hours of troubleshooting.
    Cheerio
    lululee
  • Please switch the Viewport to smooth shaded preview, applying modesty bars to the image is not acceptable.
    Are you sure there wasn't a dFoce modifier applied to the base figure?
