Living water?
Project Hexium
in New Users
Hey. I'm semi new to Daz3d. I've made content over the last few months ans I've got a idea I want to ask if anyone knows how to make? I'm wanting to make a gen8 female body be made of water if that's possible? Her skin is water and see though. I have attached a image I goggoled to show what I mean.
Anyone know of a way to do this? And sorry if this is in the wrong place.
Thanks PH.
You could select the figure, then in the Editor tab of the Surfaces pane click the figure's name (that will select all of its surfaces), then in the Presets tab of the Surfaces pane, under Shaders>Iray>Liquids there are a couple of water shaders that can be applied to all selected surfaces on all selected objects by a double-click - the one named simply Water would be my first choice, Water - dispersive blocks some light which may or may not be a good thing. Do bear in mind, however, that the figues have some inside detail but are not fully detailed so you may get odd appearances.
Great Idea
I was able to accomplish this render by using the shaders in Sickleyield splash pack II https://www.daz3d.com/rigged-water-iray-2
