Shader Mixer: How to Merge two images?
I'm working on an non-PBR shader in 3Delight. I got the highlights (A) down, I got the shadows (B) down, now I need to merge the two together.
I have tried it with the Mix brick using an Alpha of 0.5 but the end result is washed out.
I have tried a Binary Operation brick but the end result changes my colors.
How can I achieve the A+B look?
One a side note. Is there a brick which adds a blur effect to the whole image?
  • Faux2DFaux2D Posts: 456
    I figred it out. I should've just used the shadows as an alpha mask. I was just being a moron and thought there was some special brick to achieve this look.
    I don't know how to delete this thread.
  • messuexmessuex Posts: 10
    What settings did you use to accomplish this?
