How to edit Magazine/Book prop textures / covers?
billyrosco
I'm using Luxury Private Jet, and want to change the covers of the magazine props for a render I'm doing.
When I got into the Surfaces tab, and select the Base Color image, I select the new image I want to replace the original cover with. When I do this, however, neither the texture nor the preview image change to the new picture I've chosen. Does anyone know what I'm doing wrong?
I've included a picture to show a little of what I'm talking about. Thanks very much!
How did you replace the cover image? If you just replaced it with a different image, then it most likely doesn't fill the correct location. In that case, open the original image in a image editor, replace the image section with your preferred image (make sure that it is placed the same as the original) and save with a new name. Now browse to the saved image and load that in the Surfaces tab.
Hi there Doc, I did exactly what you said and it worked! Thanks a lot!
