General Freebie Requests
1568101150
  • IanTPIanTP Posts: 1,329
    Dollygirl said:
    I am looking at a Daz tutrial and I am looking for the DS alternative shader pack that used to be here - http://free.daz3d.com/free_weekly/detail.php?free_id=249 referenced from this tutorial here - http://docs.daz3d.com/doku.php/artzone/pub/tutorials/dazstudio/studio-toonshaders
    Many thanks for any help :)
    Ian,
    I think that what you need is the following link:
    DAZ Studio 3 Default Shader Presets by Digitani.
    Digitani has provided a readme file that explains where the files need to go. Placement of the scripts is the same location under DAZStudio4 as for DAZStudio3 if you are using DAZ Studio 4.
    DAZ did not provide the DAZStudio2 defaults when they put the DAZStudio3 package together. He modified the bricks and put together in the zip.
    Whoops never mind. You already know all about it.
    Thanks Dollygirl :)
    These don't work in DS4. Trust me: I've tried.
    Thank you, i'll be using DS3 for this :)
  • TSasha SmithTSasha Smith Posts: 27,307
    I have the mil puppy. are there any free props that would look like puppy puddles? is there a puppy poop prop?
    how about chewed toys for the puppy?
  • nitehawk_ltdnitehawk_ltd Posts: 387
    edited July 2012
    Trekkiegrrl has a morphing puddle & a poop prop http://trekkiegrrrl.dk/prp2.htm
    Plus other nice stuff.
    Gerrry
    Post edited by nitehawk_ltd on
    Gerrry
    The morphing puddle would need to be recolorthanksed as puppy puddles are usually yellow.
    Gerrry
    That's very easy to do. Check the opening page of my website to see what I mean
  • SteveM17SteveM17 Posts: 1,060
    I'm looking for some simple full MATs for the standard M4 figure. It sounds like it's something that could easily be found, but I've had trouble locating some. Must be doing something wrong on Sharecg and rederosity.
  • KeryaKerya Posts: 10,943
    At Rero I browsed instead of the search:
    http://www.renderosity.com/mod/freestuff/index.php?section_id=418&
    I haven't got round to updating this list and posting it over here, but this is the M4 freebie list from the old site.
    My personal favourite is Nicholas, which has so many variants in the 3 files.
    http://forumarchive.daz3d.com/viewtopic.php?t=173079
    Thanks guys, my M4 now has some new skin!
  • DollyGirlDollyGirl Posts: 2,701
    Steve if you have DAZStudio 3 then the following link can help you broaden your skin texture choices. Studio4 might work but I have never tried it.:
    Using Textures
    Using Textures
    Thanks. These instructions work fine in Daz4 until it says to click on "advanced" in the surfaces tab. I can't find it. Nor can I find "UV Maps", only "UV Set" which only offers default uv.
    Anyone know what I'm doing wrong? I bet it's something obvious.
    Thanks Pam, Nicholas has been well and truly snagged :)
  • fixmypcmikefixmypcmike Posts: 19,701
    SteveM17 said:
    Using Textures
    In DS4 "Basic" is "Presets" and "Advanced" is "Editor".
    There's a bug in 4.0 with using alternate UV Sets on Gen 4 figures -- it's fixed in 4.5
    SteveM17 said:
    Using Textures
    Is there any way of making it work in 4.0, because I don't want to mess around installing 4.5. I hear many complaints along the lines of "I've just installed the latest version and now all my content has disappeared"? In the editor tab there's no way to change the UV maps that I can see.
    SteveM17 said:
    SteveM17 said:
    Using Textures
    Unfortunately I don't know of any workaround. UV Sets is at the top of the Surfaces Editor tab for the DS Default Shader, but it only works on Genesis in 4.0
  • Richard HaseltineRichard Haseltine Posts: 108,465
    SteveM17 said:
    SteveM17 said:
    Using Textures
    If you feel a bit more adventurous one option would be to get the free UV Mapper Classic. make a copy of the current OBJ file. Load the OBJ file for the new UV set into UV Mapper Classic and save a .uvs file. Load the copy of the M4 OBJ into UV Mapper Classic, then load UVs and select the file you saved. Save the OBJ. make a copy of the Michael 4 cr2. Open it in a text editor and change the two geometry references to point to the OBJ you saved from UV Mapper with the new uvs. It means loading a neew figure to swap UVs, and you can't mix and match, but it is an option.
  • Oom FooyatOom Fooyat Posts: 0
    I am looking for V4 skin textures that are ok to redistribute.
    Will use it in a shader-project that might be a freebie some day.
    Cheers! Oom
    Is there a good police box somewhere?
    Cheers! Oom
    That will be very difficult to find. Even most paid for Merchant resources don't allow redistribution as freebies, even if you comply with the terms of their eula.
    Browsing through this thread in the old forum may give you something. It is not very up to date though.
    http://forumarchive.daz3d.com/viewtopic.php?t=139614
  • aldemps_65d152c25faldemps_65d152c25f Posts: 157
  • JimmyvermoensJimmyvermoens Posts: 0
    Hi :3
    I'm looking for freebie clothing for Hiro 3. Been looking high and low for clothes on this guy and there seems to be diddly much xD Can't exactly add this guy when he's nekkid.
    Also, whilst I'm here and on an unrelated note: What does "Hiro 3 to David" mean, since that's what the char is called right next to Hiro 3.
    Kthxbai :3
    Adzan has a nice selection of Hiro 3 clothing at ShareCG
    http://www.ShareCG.com/pf/full_uploads.php?pf_user_name=Vintageadzan
    WHOO, thanks for that :D
    edited July 2012
    Edited: tooo late ...
    Textures for Adzan's clothes for Hiro:
    http://www10.sharecg.com/search/index.php?q=adzan&button;.x=0&button;.y=0
    Post edited by Kerya on
    edited July 2012
    Cheers! Oom
    Thank You!
    I know this would not be easy but, to my surprise, I did find one :) (and half a ton of other useful stuff)
    http://www.sharecg.com/v/40114/view///
    After a look at the ReadMe I'm not sure what the intention of the creator is.
    I only need the textures as place holders so I might resort to my very inadequate texturing skills and make something.
    Oom
    Post edited by Oom Fooyat on
    I did get some textures that I missed. Thanks for that link!
    Bring it christmas, I'ma ready for ya!
    :D
    Did you browse Rero?
    http://www.renderosity.com/mod/freestuff/index.php?section_id=287&
    Mostly textures, but some clothes too.
