Adding to Cart…
You don't have such tool in DS but you can instanciate anything to the number you want if your Hardware is able to handle it (I got it up to 1500 genesis but the viewport was beginning to be very sluggish)
The only problem then is that you have to move each instanced object to the place you want it to be and when you have a lot that is quite time consuming. I didn't find a way to move a whole group of instanced object
Hmm. With the Bryce instancing brush you can actually ''paint' the instances onto an image of the terrain, is quite handy although pernickety to use. Not sure I would want to try 1500 figures though :roll: And you can move the group as a group if it is not placed just right, but I am actually not certain if you can move individual instance. As I said I mainly use it for vegetation and such, as in this image, which does have several hundred trees. http://www.daz3d.com/gallery/#images/6057
cool it works and rendertime is no problem :) have a look at the glasses :)
