Render Throttle Iray
Really loving this new product called Render Throttle.
https://www.daz3d.com/render-throttle-for-iray
It has speeded up the Iray Viewport preview responsiveness, and my PC fan is no longer running constanly.
However, the first time I use it after launching DAZ Studio, I get this error message. So I have to highlight the DrawSettings pane, and then it works.
So I wonder why it behaves this way? Once the DrawSettings pane is clicked, the product then works regardless of which pane is active.
It kind of an annoyance. Not really hindering me from using Render Throttle, but the error message (see screenshot) says you have to make the DrawSettings pane part of your layout. Well, I did that, it is part of my default layout, and it still gives the error everytime you use it after opening DAZ Studio.
If anyone is having the same issue, or if you know of a solution, please let me know. I would greatly appreciate. Thanks.
  • It could be a load order thing. I'd try moving draw settings above render settings.
  • vonHobovonHobo Posts: 1,715
    I did that it had no effect. Thank you for the suggestion.
