Transparency problem
Eric3dddEric3ddd Posts: 67
I'm struggling getting an object to look transparent. I played with all the settings, but it always looks white. Suggestions?
  • dot_batdot_bat Posts: 373
    if its 100 % transparent you wont see it. try putting in a ground plane and some lites, some other objects. play with hilites and shininess, reflection. put in a wall... something for the transparency to react to
  • Eric3dddEric3ddd Posts: 67
    The problem was the color channel. I had to darken it a lot.
  • DUDUDUDU Posts: 1,945
    Two things, first is that you have presets of glass in your content, the second, it is that you have a alpha channel in your shader…
    The alpha channel is set to "none" and all my presets disappeared when I upgraded to 8.5 :(
  • BrianP21361BrianP21361 Posts: 815
    edited January 2014
    Eric,
    Here is a quick render using the "crystal" preset. I added an HDRI image to give it some reflection. That helps it look more glass like. The second image is the shader tree so you can reproduce it yourself. I hope it helps. I added a couple more screen shots so you can see the rest of the settings.
    810 x 567 - 135K
    799 x 573 - 95K
    809 x 568 - 123K
    640 x 480 - 145K
    788 x 623 - 130K
    Post edited by BrianP21361 on
    edited January 2014
    Ah, your content became transparent itself ! :cheese:
    Post edited by DUDU on
    I was going to suggest that there may be two domains a top and the side. The side appeared transparent and the top appeared opaque. The color can also effect it as you discovered.
    Also, I think DUDU's point about the alpha channel was misunderstood. If you have it off, your object will be opaque. If you use a slider, you can adjust the alpha to make it completely opaque, to completely transparent and all point in between. The difference between the alpha channel and the transparency channel, is that the alpha channel does not have any refraction, absorption, etc. It's kind of like adjusting the opacity in Photoshop.
