Carrara - iclone 5
bsonicsoulbsonicsoul Posts: 0
How can I characters into Carrera from iClone 5?
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,434
    edited January 2014
    oops misread
    you need Carrara 8.5
    the FBX does not work on other versions for importing iClone FBX
    it will import or open the exported pipeline FBX animation files
    you will need to add inverse kinectics to the bones if you wish to pose them yourself
    choose animation inverse kinectics ball joint selecting the top bone in heirachy and all children
    that top bone may then need ik removed under motion tab to transform it
    you can make an animation group and save the motions as NLA clips that will work on other figures the same generation ie violet and Kane will use same bones, likewise Gwynn and Chuck but cannot go between.
    facial animation imports too
    can save those bones as NLA clips seperately too unticking others.
    search NLA for more info
    here is a link to creating and puppeteering NLA clips on non-Daz content
    Daz poses and animations will not work on your figure unless exported with it from iClone after importing them via genesis etc
  • DartanbeckDartanbeck Posts: 21,988
    Really?
    That is too cool to know! iClone5 just looks like a blast to play in for characters. Perhaps this will be the year I get it.
    Dart will tell you plenty on animating FBX imports!!!!!!!
    using target helpers, the keyframe and graph editor etc
    I've never used FBX yet :(
  • DUDUDUDU Posts: 1,945
    The importation of .fbx never worked for me, only the .pz2&3 and the .bvh function well…
    I have not C8.5, is it better now ?
    Check the info up a few posts. I guess in didn't really work right until 8.5, but Wendy would know much better than me
    And why was there the option if that didn't work ?
    Are there several kinds of .fbx?
  • bighbigh Posts: 8,147
    O ya !
  • bsonicsoulbsonicsoul Posts: 0
    Ok thanks, I will try 8.5. If I get it to work it will be real cool!
