Fixing objects in a modified form
I applied several modifiers to an object. Now I would like to change the object so it will permanently stay in the modified form, after removing the modifiers. How can this be done? Is there a plugin?
Thanks. :-)
Thanks. :-)
Hi Eyos :)
Export as OBJ, ...then import it
that will give you what you want
Hope it helps :)
Thanks a lot, it does what I need.
