Broken Morph - Growing Up for G8M
Hi there,
For several days now this makes me go crazy:
When i apply the "Youth Morph" to a new G8M it looks legit at first, but when i save the morph/figure as a scene subset and re-open that, it just looks like a deformed monstrosity.
I had several morphs installed, but deleted all of those. Now I even deleted everything and did a re-install of DAZ 4.12 and just the G8 basics and GU. It didn't solve the problem. I don't know what else I am supposed to do. The log doesn't show any problems with the morph and there are no hidden morphs shown that explain this.
Could it be there is another morph still active? New product you recently installed? There is a setting to show all morphs, see if any are diales active on a new character that shouldn't. I once had a character always was "on" by default, messing up the geometry like your example.
The morph activates some others, but as you can see the distortion is present even when I dial all others to 0.
EDIT: Guess I should give him some briefs to accomodate to forum policy.
Please switch the display to Smooth Shaded when taking a screen shot of a nude figure, even if it is lacking its anatomical elements.
The distortion on the head looked like a distorted bone placement rather than a bad morph, but with just the base and growing up installed I can't think how that would happen. You might go to Edit>Preferences and click the button to clear the DSON Cache.
Clearing the DSON cache didn't help either. When I re-open the saved subscene or scene - it is distorted just like before. During the initial apply it looks fine.
For everyone else having this problem, it looks like I found the problem:
In "My Library" was a folder created by the G3M to G8M converter that seems to have caused the problems. It didn't get deleted when I deleted my content and re-installed DAZ. After deleting that folder my saved figure loaded fine. Finally.
Is that the Riversoft converter, or XTransfer?
The one from Riversoft iirc. I never want to take a look at that script again. It gave me headaches for days.
