DAZ Dog 8 Tongue
In DAZ Dog 8, the tongue has two slider morphs, to side and out. Doesn't appear to be a way to 'grab' the tongue to lift off the default positions where the bottom teeth pierce the tongue. I do have the Mesh Grabber, but I haven't gotten used to working with it. Is there a way to raise the tongue otherwise? This happens in the other DAZ Dog 8 breeds, too.
  • HavosHavos Posts: 5,626
    edited January 2020
    The tongue is rigged and has several bones. Click on the head and then in the Scene pane move down the hierarchy to the Jaw, and then you will see the Tongue Base, and other Tongue bones under this. These you can bend, twist, resize etc like any other bone to achieve what you want.
    Post edited by Havos on
  • GordigGordig Posts: 10,666
    edited January 2020
    Posing sliders are convenient when they work, but they can't cover all use cases. The dog's tongue has six bones, so it's capable of much more granular posing than the pose sliders. Try playing around with manually posing the tongue. Personally, I wouldn't use something like Mesh Grabber for a case like this without exploring other options first.
    Post edited by Gordig on
  • IceScribeIceScribe Posts: 694
    edited January 2020
    @Havos and @Gordig
    thank you for the super advice!  I have located the tongue in the Scene hierarchy, and successfully lifted the portion over the teeth, even within a pose.
    Post edited by IceScribe on
  • kyoto kidkyoto kid Posts: 42,094
    ...maybe we need a Tongue Control for Dog 8?
