Without Jeans
Hi, someone can help and make me understand why after I unwear skinny jeans on G8F it seems I loose surfeces in the pelvis area?
Many thanks.
  • FSMCDesignsFSMCDesigns Posts: 12,849
    What is the product used?
    Chances are the PA was lazy and included a script that hides that mesh when loaded to save them from dealing with pokethru. Just check the hip or pelvis surface tab to see if the opacity is turned down or hidden in the scene tab
  • VisuimagVisuimag Posts: 578
    Some shoe products have similar issues (Geografts)
  • nabob21nabob21 Posts: 1,057
    I have encountered the problem with the shoes. Is there a way to get the missing parts to show up again after I remove the shoes?
    the shoes usually come with a remove morph, might check the shoe folder options
  • FenixPhoenixFenixPhoenix Posts: 3,188
    edited January 2020
    The easy way is to delete the jeans or shoes. That should reset the figure. Hiding them won't work. Another way is to edit the duf file and delete the graft from there. Of course, I recommend saving as a different file in order not to mess up the original product.
    I took a screenshot this suggestion (don't remember the username, so can't give proper credit) a while back (2018) so I'm posting the image (as I don't have the thread in my bookmarks anymore, otherwise I would link):
    1080 x 2220 - 409K
    Post edited by FenixPhoenix on
