Mirror image figure?
Is there an easy way to mirror image a figure?
I have two figures with the same pose, but I want to reverse one of the poses. The pose set does not include mirrored poses, so I will have to find a way to do it myself.
Any help would be appreciated. I could not find anything when I googled this subject, so I am not sure how to do it.
  • vonHobovonHobo Posts: 1,715
    I tried changing the X Scale to -100 which was reccommeded in the forum for mirroring objects. But look what it did to the figure. Oh my.
    So that does not work for figures.
    662 x 665 - 219K
  • roni190roni190 Posts: 40
    1) Shift + Y then from top to bottom
    2) Nodes select Root
    3) Propagation Select Recursive
    4) Direction Swap Left and Right
    5) Trunk Nodes Mirror Y and Z
    439 x 583 - 65K
    edited January 2020
    This might help. {several options to work out which one(s) are desired}
    Post edited by Catherine3678ab on
    Thanks! I will give that a try.
    Wow! That worked incredibly well! Thank you for the responses.
    662 x 665 - 252K
  • You're welcome :-)
