Mirror image figure?
Is there an easy way to mirror image a figure?
I have two figures with the same pose, but I want to reverse one of the poses. The pose set does not include mirrored poses, so I will have to find a way to do it myself.
Any help would be appreciated. I could not find anything when I googled this subject, so I am not sure how to do it.
I tried changing the X Scale to -100 which was reccommeded in the forum for mirroring objects. But look what it did to the figure. Oh my.
So that does not work for figures.
1) Shift + Y then from top to bottom
2) Nodes select Root
3) Propagation Select Recursive
4) Direction Swap Left and Right
5) Trunk Nodes Mirror Y and Z
This might help. {several options to work out which one(s) are desired}
Thanks! I will give that a try.
Wow! That worked incredibly well! Thank you for the responses.
You're welcome :-)
