A question the FM Fight Club Scene
In this scene, I would like the action to revolve around the wrestling/boxing ring. However,
I am not sure how much trouble I would have to go through to actually put figures in it.
What I'm saying is, I don't want them to go through the floor of the ring.
Also.for some of the fight club poses, it says that there is a different pose for in ring action and out
of ring action. Can I position characters in the ring with other poses, or does it have to be these?
Thanks!
The poses appear to be for 'in the ring' or 'floor level', which is really self-explanatory. I would expect these poses to be set to the correct height to look like they are standing in the ring or on the floor.
If you want to use other poses not from this set, then you would need to adjust the 'Y' (height) parameter to be the same as the Ring or Floor poses that ARE supplied.
Is that what you mean? There is no way to drop figures onto a stage or other object, but you can drop them onto the floor using the Ctrl+D hotkey.
yes. that is what I meant. thank you!
