DIM & all downloads not working today
Wonderland
in The Commons
Today when I try to download through DIM, every item says "Download Failed!" and it only downloads a portion of the files, just several kb that show as PART files. When I try to download manually, it shows complete zip files of 0 kB. Can't get anything to download today. Anyone else have this problem? And how do I fix this?
I've just been downloading today's purchases, and now I'm downloading some older files too - no errors. It may be an issue on the path from you to Daz, you may need to try again tomorrow. If you need to grab the content today, either try using Connect (downloading within DS) or try getting the zips from the Product Library pages here at Daz and drop those in the DIM downloads folder for isntallation.
I downloaded purchase this morning (CST) w/o problems.
For over an hour of countless tries, nothing would download either through DIM or manually then suddenly finally was able to download although some items I had to click like 20 times before they'd go through. My internet is fine, 5GHz, so not sure what the hiccup was, but everything is finally downloaded. Now I have to see if it installed correctly because I've been having problems with that too. Some DIM items, including recent products, just won't install...
..I've experienced that from time to time myself. Would og through all the system checks and diagnostics to no avail. Then the next day it runs nice and smooth again. .
I had about 60 downloads yesterday and of those only 1 failed and it was probably because of my cable internet provider's technical problems. The DAZ forums and DAZ Store on the other hand have a whole different set of problems.
