After installing Windows 10 I dont know where to manually install content
Hi!
I've recent bought a new PC and now running Daz Studio on Windows 10. I've used Windows 7 before and no longer know where to manually install new content to Daz Studio on Win 10.
I now have a map called My Daz Connect Library containing "data/cloud/ (that is empty).
In C:users/my user/documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/ the cloud map is also empty.
I have no idea where to manually install stuff anymore.
I've tried the latest version of Daz Studio as well as older versions. Any advice?
The My Daz Connect Library is used, by default, when installing content from within DS (through the Install pane, Smart Content>Products tab, or the Products list in the Content Library pane). If you don't use that it will be empty. For Install Manager or manual installs the procedure has not changed, though if you have an SSD for your C: drive you may want to use a mechanical drive, if you have one, for the content dirctories (if you had moved your Documents folder before installing DS that should already be done). One issue to watch for, if you sign in using a Microsoft ID, is the documents folders being moved to their OneDrive cloud service instead of being on the local drive which can cause confusion as the local drive will then not have your content (and OneDrive will rapidly fill up).
Yes, got it to work by reinstalling it on my mechanical D:drive.
