Did Vairesh set up "shop" elsewhere?
RedfernRedfern Posts: 1,647
I think the subject line pretty well states the question.  When Vairesh left DAZ as a vendor, did he (or she) set ip shop at another site?
To the point, I'd like the purchase the "Aisha Hair for Victoria 3" which "vanished" when Vairesh did.  I'm planning a composition that will depict the Na'vi from James Cameron's "Avatar" and the and "CS" at ShareCG provides a texture that uses that hairpiece.
I know what somebody likely recommend, the "Wild Dreads" package.  I have that item already and will rely upon that as a "backup" if my search turns up goose eggs, but I'd rather employ something a tad more "screen accurate" if possible.
Sincerely,
Bill
    I haven't seen anything at all from Vairesh for years and years.
    Laurie
    Sincerely,
    Bill
    Are you sure you have the name right    I have Ayiana hair by Vairesh
  • There's this inexpensive product at renderosity. hfs-races-navarian-hair
  • FishtalesFishtales Posts: 6,224
    Sincerely,
    Bill
    Any of these do.
    https://www.daz3d.com/catalogsearch/result/?q=vairesh aisha hair
  • RedfernRedfern Posts: 1,647
    edited January 2020
    Chohole said:
    I simply "copied and pasted" the infornation "CS" at ShareCG.  If it' in error, it's one going back a stage with "CS".
    Here's the image "CS" used as a showcase image for the texture add-on he offers.
    https://www.sharecg.com/images/medium/61040.jpg
    (Linked instead of "inline" in case that would otherwise violate forum policy).
    I will admit, however, that I assumed Vairesh made the original product because that is the texture subfolder "CS" used to place his custom texture, as follows...
    Runtime/Textures/Vairesh/Aishahair/Aisha Holztexture
    Again, if Vairesh did not make it, then the directory structure "CS" provided is misleading.
    Sincerely,
    Bill
    Post edited by Redfern on
  • HaruchaiHaruchai Posts: 2,040
    Apologies I can't help directly with the Aisha Hair (I have the CS files too, always intending to pick up the hair and never did) but Blue Soul Hair by outoftouch is something that I've used succesfully for this type of character. And it's for V4 so easier to fit to modern characters.
