Shaders
VIArtsVIArts Posts: 1,526
I feel like a noob, so hi. :D
In DS4.6, I've selected stuff in both the Scene and surfaces tab, then tried loading a pwToon shader. Nada happened. Whassup with that/?
  • JaderailJaderail Posts: 0
    The Default pwToon is pretty hard to see until you render. It will not Change the Viewport all that much.
  • VIArtsVIArts Posts: 1,526
    Rendering shows no difference. Plus, it still says DS Defaultv shader in Surfaces.
    Ensure that both the model is selected as well as a surface on that model before applying the pwToon shader and it should work. If it's still not working, ensure that pwToon is properly installed as you might be clicking on a preset intended for use with the shader. Some presets simply adjust settings on an existing pwToon shader rather than applying the shader itself (similar to Crescent's pwToon shaders which I have linked below).
    Also be VERY sure that you have the LAST pwShaders update installed.
    I think it was just that he .sdl wasn't installed. I tossed it in and BAM.
    Not as noob as we thought, huh?
