Help needed on basic shaping of Genesis in 4.6 Pro
I know this probably sounds really simple but most videos on youtube and things are all for Daz Studio 4 or 4.5 and I've only recently just downloaded Daz Studio 4.6. I am really confused because they have the female genesis character and the male genesis character but there doesn't seem to be any morphs or anything to make them children or older, or larger. I can't seem to find these kind of things like, "Bodybuilder", which were in previous version...
Any help would be gladly appreciated if you could help me work out how to make an older character or something like that?
Thanks.
Genesis and Genesis 2, are completely different figures, one does not 'replace' the other.
With DS4.6, you get Genesis Starter Essentials AND Genesis 2 Starter Essentials (Male and Female), and you should install both of these bundles. There are several morphs that come free with Genesis, but I believe that Genesis 2 does not have these morphs as standard. I have been trying to fine what is contained in the Genesis 2 bundle for you.
In the meantime, you could look at this thread : http://www.daz3d.com/forums/discussion/34438/
EDIT:
List of Genesis Starter Essentials
http://docs.daz3d.com/doku.php/public/read_me/index/14812/start
Thank you so much for your help. I hadn't realised there was genesis and genesis 2. I will look at the links and try to work it out. Thanks again.
When you say you get Genesis Starter Essentials AND Genesis 2 Starter Essentials, where can I find the Genesis Starter Essentials as I can only find the Genesis 2 ones? Thanks.
If you are using DIM (DAZ Install Manager) they should be included there.
If not, go to 'My Account' at the top of this page, then select Product Library, which will give you a listing of everything that you have bought through the store (free or otherwise). It is also searchable if necessary. Download from the links there.
Thanks so much... I've found it now.
