Never had this happen before FIXED
TrishTrish Posts: 2,625
edited January 2014 in New Users
I have her feet and toes hidden see first picture ...when I render they show up...??? any ideas would be appreciated....Thanks Trish
Post edited by Trish on
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,541
    Must be your render settings
    is there a render hidden objects option in Daz? (I know there is in carrara and iClone, not on my PC at moment)
  • JaderailJaderail Posts: 0
    That sounds to me like a failed scene file. They should stay OFF in render. Try loading the file Turning them on again, SAVE as new scene File then TURN off again and SAVE as NEW (Diff name) Scene file. It that still fails just turn them OFF with the Opacity setting in the Surfaces Tab.
  • TrishTrish Posts: 2,625
    edited January 2014
    Ok thank you both for the quick response .. P.S. I ended up going into surfaces and turning the opacity to zero..on feet ,toes and toenails
    925 x 481 - 83K
    The new AoA SSS shaders don't obey the visibility switch.
