Content Management Service not working
Hello.
I need some help installing the Content Management Service. During the installation of the DAZ install manager I got a message saying that the installation of the Content Management Service could not be completed properly. Even the Uninstaller of the Content Management Service isn't working "Not a a valid Win32 application".
What can I do?
CMS is normally part of the DAZ Studio main install, and if you use DIM, it should all be installed correctly.
What version of DS were you installing, what OS are you using, and if Windows, you need to make sure that you are installing the correct bit depth for your system, I.e. the 32 bit or 64 bit version.
I figured it out. I had to delete the old CMS service. After I did that everything installed correctly.
Thank you.
