Dresses Created in Marvelous Designer 9 not loading in DS 4.12
souwritray2009souwritray2009 Posts: 18
edited January 2020 in New Users
I had Created this dress in Marvelous Designer 9 :
Now I wanted to import this dress in DS 4.12 and use it on the Gen8 female figure, I saved it as OPSS 2.obj But it did not show up after import, although it can be seen in the Scene Tab :
I need help on this.
Post edited by Chohole on
  • barbultbarbult Posts: 26,299
    I suggest joining the MD conversation in the ongoing The Marvelous Designer Thread. You are more likely to attract the attention of MD users who have been following that thread.
    Maybe it is a scaling problem on the export and/or import of the OBJ. Hide G8F. Select one of the OPSS-2 items in the scene pane. Type Ctrl-F to frame the selected object in the viewport. Can you see it now? If so, it may have been scaled so tiny it was inside of G8F or so large it was way outside of the viewport.
    If you are unable to resolve the problem, paste in some screenshots of your MD export settings and your Daz Studio import settings.
    Another possibility is that the dress imported with all the materials transparent. This happens sometimes — there are lots of things that can go seriously weird with an .obj import, this isn't the weirdest I've seen.
    I notice you have two objects in the scene, "OPSS<dash>2" and OPSS<space>2". Which is the one you imported?
  • alexhcowleyalexhcowley Posts: 2,403
    There's an embedded blank in your file name. That has caused me problems in the past, with wavefront object files.
    Cheers,
    Alex.
  • LyonessLyoness Posts: 1,637
    Also, make sure that you Created your UVs properly so that the textures can be viewed and applied.
    I did exactly that and this happened :
    Now what to do?
