How to correct the Jacket?
Leo ChenLeo Chen Posts: 697
I am trying to put "Afternoon Trippin" on V6 but fail.
Part of the jacket is inside the skirt.
I just can not find anything to tuck in or out the jacket.
    There are a number of morphs for the Jacket, from the Product Page:
    ◦Jacket
    ◦Adjust_HipFront
    ◦Adjust_Tail
    ◦Button1_InOut
    ◦Button1_UpDown
    ◦Button2_InOut
    ◦Button2_UpDown
    ◦Button3_InOut
    ◦Button3_UpDown
    ◦Button4_InOut
    ◦Button4_UpDown
    ◦Chest_out
    ◦Chest_wider
    ◦CollarLoose
    ◦CollarThicker
    It would seem that you need ◦Adjust_HipFront . If you select the Jacket, and go to the Parameters pane, it should be there.
    This item is also made for Aiko5 and Genesis, not V6 and Genesis2.
  • Leo ChenLeo Chen Posts: 697
    Thank you, JimmyC_2009.
    I find nothing but FBMExpandAll in "Shape pane" and "Parameter pane".
    I just shift back to try Gensis female.
    These morphs are in the parameter Pane.
    But, what we can do with the V6?
    V6 is a morph of Genesis 2, which is a completely different figure to Genesis (original).
    It looks like these morphs wont work with Genesis 2 unfortunately.
    Does Autofit pop up when you try to load this clothing onto Genesis 2? If so, I would have thought that the morphs would carry over as well. You could try loading it onto Genesis 2 before applying the V6 character, and see what happens.
    edited January 2014
    It is strange.
    I removed the jacket and re-added it, the morphs came back.
    As you can see in image 2, there is "Morphs" in the "Parameter Pane".
    The image 1 was taken before I removed and then re-added the jacket.
    There is no "Morphs" in the "Parameter Pane"
    1052 x 513 - 349K
    1370 x 595 - 425K
    Post edited by Leo Chen on
    Sometimes changing the collision item, if the problem clothing has smoothing applied, can solve the 'under when it should be over' issue. Say you have a shirt and jacket. If they are both fitted and collide with Genesis, you'll probably end up with a jumbled mess. But if you keep the shirt set to collide with Genesis, then set the jacket to collide with the shirt, it will usually look right.
    Thank you,mjc1016.
    PS:
    I am still learning and don't know anything about "collision". :red:
    I will learn harder...
    In the screenshot of the 'before' jacket, if look at the Parameters, the last item under General is Mesh Smoo...(in your shot), that is Mesh Smoothing. The collision settings will be found there.
