To Reset Head Pose Takes Forever
LenioTG
Hi everyone, and happy new year! :D
I was wondering: do you know how to quickly reset an expression?
I know every set of expressions has a zero pose, but I have countless expressions sets, so I don't always recall which one I used (I scroll many expressions each time, looking for the one that best fits a particular scene).
I've assigned the shortcut "-" to "Reset Element Pose", I usually select the head of one or multiple figures, and I hit "-".
It takes forever. I haven't measured the time, but it's something like 5 minutes.
I've tried the reset poses set from DeviantArt, that works surprisingly fast for all other body parts, but the head function just resets the head element pose, without resetting the expression.
How do you do this?
Thanks!
I know this isn't a reset trick, but if you go to your posing tab and click on 'currently used' at the top (under 'All' and 'Favourites') with your target figure selected, it literally just lists any current expressions/posing parameters you've used, so you can quickly see which ones are applied without having to scroll through all of your library.
Just click back on 'all' when you want everything back in the list :) . I use it a lot for killing ear morphs in hair (under the Parameters) tab, rather than having to scroll down through every option as it just flags up the ones used.
Thanks, I don't use that pane, now I know what parameters are applied, but is there any way to reset them fastly?
There are many of them, and setting 0 to all of them takes even more time.
BTW, it takes 8 minutes to reset an expression :O
Maybe create a pose preset with all the face dials at 0? When you get to the dailogue box, use the main toggle to toggle everything off, then open up the pose control, and check the head box.
