Two questions about using Dystopia City Blocks!
Alfhak712Alfhak712 Posts: 94
I am new to this things but love DAZ very much and what you can do with it!
I get the Dystopia Cityblocks 11 - 20p and it says that each block should fit the grid by 400 meterx400meter
very easy! Then I load up one block and have the Genises figure there! The figure looks like King Kong
or a "GIANT". To get it looks ok, I have to scale the block up 1400%!
My questions is what do I do wrong?
I am totally new to this and now discover in the information!
•Requires Poser 5 or above. Some features require Poser 6 or above
What does that mean? Do I need to get Poser 9 to have everything working?
Thanks in advance!
  • bighbigh Posts: 8,147
    no you don't need poser - some models are going to be to big or to small in DS
    just the way it is .
    just make one or the other bigger or smaller .
  • pwiecekpwiecek Posts: 1,598
    Dystopia blocks were meant to do really large scale cities. They're not meant for street level renders.
    If you want to use them that way you will just have to use the scaling.
    If you want a large scale view with some REALLY tiny people, I suggest you get some low res people.
  • Alfhak712Alfhak712 Posts: 94
    Thanks for the reply!
    I was just little confused then it say it should fit the grid and also the size of
    the blocks should be 400 meter x 400 meter!
    I was thinking what would be best scale up the individual blocks or scale down
    the people! Depends on what kind of scene I will do and then render!
    Thanks!
  • SimonWMSimonWM Posts: 924
    Create a primitive plane in DAZ Studio and give it 400 x 400 meter dimensions, then scale distopia to cover that plane.
  • SzarkSzark Posts: 10,634
    edited July 2012
    I have all the Dystopia Freebies for the Daz Store some years ago and it came with a few scaling presets. One bieng 1200% which I think corresponds to the hieght of the figures.
    They should be under Poser Formats > Dystopia > City Blocks
    422 x 993 - 105K
    Post edited by Szark on
