General Freebie Requests
Adding to Cart…
I expect You could get Thornes Universal wings, which includes the dragonfly textures, at FaerieWylde, as that is his site.
I forgot about that site. Do you have a link to it as I lost it?
Here you go And yes the universal wings are there. In fact it says updated, wonder what is new.
http://www.faeriewylde.com/FW4/
Can anyone point me to DeltaX15's Move Origin script? The old bookmark is lost.
http://www.4shared.com/dir/722776/10801f63/DS_Scripts.html
P.S. This works in DS4Pro Version 4.0.3.47 if anyone needs this.
Here are some textures for the Butterfly at Age of Armor (see response from Kerya)
http://www.renderosity.com/mod/freestuff/details.php?item_id=57071
-These were the two I had found. Thanks anyways both of you.
Hi to all!
Do anyone knows of a link to a freebie of a typical French style "Cloche" hat from about the 1920's/1930's or so?
On searching via Google I noticed there was one mentioned in the old forums but when clicking on that link it doesn't exist anymore since it was part of Daz old forums. In the Google description of the forum link not working I have picked up that such a cloche hat was modeled by a Chris Palomino or Cris Palomino perhaps?
Thank you for any help.
Kind regards,
Laura
You need to change "forum.daz3d.com" to "forumarchive.daz3d.com" to make the link work:
http://forumarchive.daz3d.com/forum_freebies/clochehat.exe
Looking for a Hooded long coat, for M4 or Genesis. Something like what I did here with Steamcoboy for M4 and Wildlander M4 cloak.
Go here:
http://forumarchive.daz3d.com/viewtopic.php?t=123
Then click on the link in the message.
A window opens with
forum.daz3d.com/forum_freebies/clochehat.exe
correct that to
Works! :)
Maybe there is one in this pack:
http://www.renderosity.com/mod/freestuff/details.php?item_id=62683
Go here:
A window opens with
correct that to
Works! :)
Thank you Kerya! But in the meantime I also got a PM reply back from Cris Palomino that she doesn't have that model anymore since it was an old item. I will go and have a look at the link at Rendo to check that out!
Thank you also for the correct links to old forums! :)
Laura
Laura
Two things... An archery target and a Puerto Rican flag texture for V4's basicwear.
http://www.most-digital-creations.com/free_poser_poses_textures_morphs_props_44.htm
Four down.
Cheers Oom
Make it three things... I've been wanting fencing gear for V4 for years. Can anyone alt least make a mask and swords?
Four down.
Thanks. Don't know how I missed your reply.
I'm not aware of any mask, but there are a couple of suitable swords out there:
Epee:
http://www.renderosity.com/mod/freestuff/details.php?item_id=68509
Fencing rapier:
http://www.sharecg.com/v/4023/browse/11/Poser/Rapier-pack-for-Poser-5-and-higher
While you didn't ask for pre-made poses, I found a set anyway:
http://www.sharecg.com/v/37440/browse/11/Poser/Fencing-Poses
For the fencing mask, these may work with retexturing
http://www.renderosity.com/mod/freestuff/details.php?item_id=49663
http://www.renderosity.com/mod/freestuff/details.php?item_id=17665
http://www.renderosity.com/mod/freestuff/details.php?item_id=63629
Does anyone know how to download stuff from the Japanese Poserclub site? My japanese is a little rusty.
Ah, there was a detailed "how to do it" posted once, but of course it was on the old forum. I wonder of anyone knows where it was.
I recommend to use Google Translate (Japanese -> English), because it can deal with Japanese reasonably well (clunky, but if you rub your braincells together, manageable). Copy-paste the page's text into the box (or point it to the page you want to translate) and go.
Check any of the compilation lists that I maintain (excepting the aircraft or tools lists) and you'll find the link:
http://forumarchive.daz3d.com/viewtopic.php?t=94994
I did it with the help of a translation program not long a go, It was not that hard. Some of the posts said you had to use IE but I use FireFox and had no problem.
Good Luck!
Oom
I used Google translate which worked fine, but when I try to register I get "invalid token" reply. Now what?
Ian,
I think that what you need is the following link:
DAZ Studio 3 Default Shader Presets by Digitani.
Digitani has provided a readme file that explains where the files need to go. Placement of the scripts is the same location under DAZStudio4 as for DAZStudio3 if you are using DAZ Studio 4.
DAZ did not provide the DAZStudio2 defaults when they put the DAZStudio3 package together. He modified the bricks and put together in the zip.
Whoops never mind. You already know all about it.
Is there a soccer or foot ball outfit for genesis?
Optitex has just put a free Football outfit for M4 up. You could perhaps use that on Genesis
http://www.optitex-dynamiccloth.com/FreebieDownload15.php
Or you could use one of my free items - shirts or shorts - and make a set up in the colours you want. Link in my signature
Ian,
These don't work in DS4. Trust me: I've tried.
