Figures vanish into thin air
Not having much luck today with anything. :(
I purchased the Midnight Scholar Poses for Genesis 8.
When I apply any of the poses the figures simply dissapear.
"The Library" is a requirement for this product, but I'm assuming that is only if you want them in that enviroment which they were intended.
Not having the environment has never been an issue for me with any other pose products.
So I'm not sure why the figures simply dissapear. They are basically invisible even though they are listed in the Scene tab, and the Uninversal tool is in the viewport.
Does anyone have a clue as to why this is happening?
  • SimonJMSimonJM Posts: 6,076
    I suspect they are just disssppearing from the preview pane as they are movign to a location within the environment.  Either press Ctrl-F to centre the figurre in the viewport or load the pose with a Ctrl-Double-click which will pop up a dialog in which youi canuncheck the X, Y, and Z Translate properties which should apply the pose and not move the figure.
  • vonHobovonHobo Posts: 1,715
    Wow! Thank you!
    I will be using Ctrl-F a lot from now on I think.
    Both methods worked. smiley
  • NorthOf45NorthOf45 Posts: 5,728
    Correct, they are "Go To" poses, placing them at various locations around The Library. The default viewport is facing a corner of the room, so all the poses will be back and to the right. Way right.
    That is one "big" library. Could not find the figure anywhere at first.
