EYELASHES! - SOLVED -
Dax Avalange
Hello Richard! (Haseltine)
I'm here again to ask you a simple question.
In my new product I'm going to sell in my store, I want add new eyelashes for G8F.
Question is, after exported from the eyelashes obj from DS and remodeled, how to reload and connect? I thought about something like Transfer Utility, but I'm not sure, cause I know they are Geograft. So, what is the procedure to get a standard default obj load?
Thank you and have a great day!
Max-S
Post edited by Dax Avalange on
You aren't allowed to modify the eyelash model and distribute the result as a new model - you need to either se a morph (if it's just shape changing) or create a new mesh of your own from scratch.
Yes, that' right - the morph name will match the filename. You will, as I recall, want the Import Morphs for setting to be the graft option for the lashes.
