Gen 8 pro
In the previous discussion about anatomical attributes it was pointed out that the attributes only game with the pro series sets such as V4 pro. This I assume is because the proseries come with the body morph package. When I looked at the Gen 8 pro series, I find there is no body morphs package and therefore no morphs. Where is it?
  • Doesn't have anything to do with anatomical elements or pro bundles, but the "main" Genesis morphs come in three versions for each gender, which are body, head, and expressions. Here as an example is the Genesis 8 male body morphs: https://www.daz3d.com/genesis-8-male-body-morphs
  • 3Ddreamer3Ddreamer Posts: 1,349
    And the anatomical elements (if that is what you are looking for) are part of the Adult Pro bundles from Genesis - Genesis 8. They came with the Morphs in Generations 4 (Michael 4 and Vironica 4) but not after that.
  • DripDrip Posts: 1,251
    Genitals on the Genesis 3 and 8 series (maybe also the 2 series, never really looked into it there) actually aren't morphs but geografts. Basically, that means they're a seperate object made specifically to blend seamlessly with the figures' body, replacing a part of the body mesh. These geografts come only with the pro bundles of the *adult* figures. Not with the kids or teens, and they don't even work with the kids or teens bodies. However, between the adult figures of a specific generation who are of the same gender, these genitals are interchangable. So if you have the Victoria 8 Pro bundle, then you can use the genitals on (for example) Zelara 8, even if you just have the standalone Zelara 8 figure without the pro-bundle. The Zelara 8 figure comes with the textures for the genitals in the standalone version, it just doesn't have the geograft object included.
    Within the pro-bundles, the genitals can be found in the folder called "external anatomy" or something like that (it's where you usually also find things like eye lashes). Make sure you have smart content set to show stuff by product, not by files.
