Black noise when rendering images
Hi,
i'm new to DAZ. While playing around i ran into an issue. In some of my renders appears black noise. The higher the resolution - the stronger the noise appears.
Any ideas what's wrong?
Hi,
I guess it is the scull cap intersecting the head.
You can check that by switching to smooth shaded view. If you see intersecting, select the hair and find a suitable morph slider to correct the intersecting. Once done, you might not get those artifacts anymore.
Please check the attached screenshots.
Perfect! That worked.
Additionally, i had to disable "Mesh Smoothing"-Option to see the intersection.
Thank you very much!
My pleasure :-)
