Noggin's Perched Crow crashes DS every time
Any one else played with these great little birds recently in modern DS? The flying crow loads and poses fine, but every time I try to load the perched crow, DS crashes. I have submitted a ticket, but I'm curious if this is unique to my machine or if it's a weird issue with the way that crow was created (my purchase date was...2004....so, it's kinda old... :) )
Here is the product: https://www.daz3d.com/noggin-s-poser-crows
  • LorraineLorraine Posts: 1,057
    I've got this, I'll give it a whirl when I've finished my render.
  • NorthOf45NorthOf45 Posts: 5,896
    Seems kind of flaky. I tried it, too, and Studio hung loading it, had to kill the task and restart. I did have a couple of figures in the scene testing out some new stuff, but nothing excessive.
    "Error importing file: C Exception: Memory Access Violation - Attempted to read memory at address 0x13f8a8a90"
    After starting up fresh, it loads okay. Go figure... Time to export as figure/prop asset.
    And so it does! Everytime a coconut surprise
    Your question sent me down a rabbit hole. I downloaded and installed DS3, opened the folded raven and saved it as a .daz file, opened this successfully in DS4.12, saved as a scene subset...boom! crash! Nothing I save it as works. Scene, scene subset, scene asset, nowt.
    And because I'm a glutton for punishment I installed and tested in DS4.5, 4.10 and 4.11, all happy with original file, all saving a duf that opened in these programs. It was 4.12 that broke it.
  • barbultbarbult Posts: 27,501
    What version of 4.12 are you testing? Some fixes for legacy items were added along the way. Check the change log.
    • Fixed #DS-1982: Some legacy figures crash on load when IK chains are present
    DAZ Studio : Incremented build number to 4.12.1.16
    I tested it on 4.12.0.86, I'll download update and check.
    There does not appear to be a 4.12.1.16 that I can download. I download everything manually and 4.12.0.86 is the latest in my product library.
    4.12.1.40 is the latest Public Beta. You can buy it in the store for $0 and install it with DIM. Public Beta will install as a separate executable and not overwrite your released 4.12 0 86. Public Beta can use the same Content Library as the release, but it has separate preferences, so you have to set all that up again. There are scripts posted someplace to make that easier. I don't own the crow, so I can't tell you whether it would fix your problem or not. Being Beta, it has caused some new problems. You should read the forum thread about it, if you want try it.
  • scorpioscorpio Posts: 8,533
    Could be the same problem as the original Plushies.
