Shader character or no shader character?
WillowRavenWillowRaven Posts: 3,787
I know this is a super-novice question coming from someone who's been using Daz professionally for 3+ years, but I'm curious, when applying a mat to a character, which mat is better, the one listed 'shader' or the ones not?
  • FSMCDesignsFSMCDesigns Posts: 12,846
    Depends on the renderer and what shaders it supports. I use Lux and Octane, so DS shaders are of not use to me. Technically the ones with special shaders are supposed to be better than none shader versions.
    For which character/base figure...
    If I'm remembering correctly, most of those listed as 'Shader' are 'optimized for Poser' settings...
  • WillowRavenWillowRaven Posts: 3,787
    OK. I only use the renderer that comes with Daz (ultra lazy ... lol). So I should use the shader one when it's an option?
    OK ... so maybe not ... lol
  • Richard HaseltineRichard Haseltine Posts: 108,656
    You may get two different sets of materials for DS, one perhaps using the default shader and one using HSS or uberSurface, but they will usually be labelled to indicate precisely which shader they use. If they are in the Poser format library then they are probably Poser-only different (especially if they don't both have the scroll icon at top-left of the thumbnail, indicating a DS script that will run when applied).
  • MattymanxMattymanx Posts: 6,998
    What character is it and what re the options?
    It's important to point out here that both of the options will be 'shaders', since the term shader refers to a set of instructions which tells the computer how to deal with the surface. Some of these will use the Daz default shader, others may use UberSurface or AoA subsurface shaders. In general you want to use shaders optimised for Daz Studio, and avoid Poser ones where possible. However, if you apply a Poser material, it will simply use the Daz Default material shader and apply the basic settings such as textures, bump and specular maps.
    They may need some tweaking to look their best.
  • Takeo.KenseiTakeo.Kensei Posts: 1,303
    There is something to take into account is that a lot of people, including some PA who confound Shader and Shader Preset
    Yep ... I knew I shouldn't have asked ... lol.
  • kyoto kidkyoto kid Posts: 41,990
    edited January 2014
    ...that depends. Older content often included separate Daz and Poser Shader files. For example Stonemason's Village Courtyard has a completely separate set of shaders for both Daz and Poser. There is a difference in the appearance of the stone, brick, and especially the water between the two shader formats when rendered in 3Delight. I'll post an example later as I have some errands to run.
    All "Daz specific" shaders will be found in the root My Library/Daz Studio/Content folder, not the Poser files Runtime one.
    Post edited by kyoto kid on
