Can't find items purchased.
Hey guys, I have purchased the following items:
http://www.daz3d.com/everyday-4
http://www.daz3d.com/facial-expressions-for-v4
I have installed both with the install manager but they won't appear anywhere in the items list in daz studio even after I loaded V4.
I have reinstalled them both 5 times as well as doing a fresh download from the purchase page but they just won't appear in my list.
Am I doing something wrong?
Version of Studio?
Version is 4.6, and the character is v4.2 base
Go to the Content Library...and look under Poser Formats...
Hey, I found both products under Poser Formats as you suggested and while I managed to get the clothes to work, the facial expressions do not seem to be working. I tried 2x clicking, dragging on top of the character and even right click - merge but nothing happens, the expression will not even show up in the scene.. Any idea why is that happening?
I don't have this set of expressions, but they probably load a dial in the Parameters pane for you to use when you double click on them.
Select the 'Head' of V4 in the Scene pane (or viewport), apply the expression, then look in the Parameters pane for a slider. You can use the sliders to mix the various expressions if you need to.
DId you initialise them after installing, as per the product page?
Okay, after a couple of 'wtf' moments since I couldn't make the head appear in scene, I figured it out and it works perfectly! Thank you for your help ! :)
I still have a question regarding what Chohole said - initialise them after installing? what do you mean by that? I went to the product page but I don't quite understand what you mean.
When we used to use the older .EXE installers, we had to run a file which was left on the Desktop after the initial install. When you are using the DAZ Install Manager (DIM), it does it all for you, so you should be set up correctly.
Ah, I see, thank you for clearing that up ;)
