Modeling Objects in Carrara - Q&A - Come One and All
14748505253
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,431
    edited December 2019
    sometimes you think something will be simple but it escalates fast ...
    1920 x 1040 - 227K
  • DiomedeDiomede Posts: 15,401
    Looks great, Wendy.  You've inspired me to share my cabin with thatched roof, although I think some textures might have to be replaced.  I will post in xmas freebies thread.
    1701 x 955 - 226K
    I gave up on thaf bit of UV mapping BTW it looked awful
  • Scorpio87Scorpio87 Posts: 82
    edited January 2020
    Question:
         Introduction to question: I have noticed this in many of my documents, whenever I use a light source over glass, the glass does not properly illuminate as one would imagine glass would glow. (especially with refracted glass). I've tried many settings such as: caustics with simple renders without any noticable effects.
    My question is for everyone here, what is your method, workaround, and or settings you use to create a more realistic light cast through transparent/translucent materials?
    My images below shows my settings and the image I am currently rendering.
    thank you
    joanght.
    4080 x 1920 - 806K
    4080 x 1920 - 858K
    4080 x 1920 - 735K
    1002 x 1298 - 166K
    4080 x 1920 - 1M
    Post edited by Scorpio87 on
    Carrara likes it's glass to have thickness
    so a an almost flat cube not a plane
  • de3ande3an Posts: 915
    edited January 2020
    I usually try to simulate the effect by activating the glow channel in the lighting fixture shader. You can also add a secondary light source if you need additional glow.
    It can take a lot of fiddling with the lighting, shader, and render settings to get things just right.
    Here are some example settings that I think look pretty good for this test scene.
    1024 x 768 - 160K
    3745 x 2335 - 4M
    2288 x 1316 - 537K
    492 x 660 - 94K
    500 x 662 - 97K
    496 x 1842 - 233K
    Post edited by de3an on
    edited January 2020
    Thank you both - I will definitely experiment with the glow channel and multiple light sources with thicker material!
    I am having an issue UV mapping
    my roof and floor won't flat map, some wedges are rotated
    file below
    zip
    zip
    Octohouse.zip
    32K
  • StezzaStezza Posts: 8,857
    edited January 2020
    had a fiddle... dunno if it's what you need yes
    created seperate material zones for roof and floor and then resized all to fit wink
    640 x 480 - 128K
    zip
    zip
    octohouse_mapped.zip
    35K
    Post edited by Stezza on
    edited February 2020
    Going through old content, I found a rat.  So here it is for free.
    Very rough, but free for any use.  See attached zip.
    600 x 600 - 14K
    zip
    zip
    rat Carrara zip.zip
    385K
    Post edited by Diomede on
  • Thanks Stezza
    and lovely looking rat Ted glad not real
    looks gorgeous.  wood floors heart
    best dresed cornell box
    hardest part is knowing where to start the proj.  >.<
    my day job uses yaggi antennas.  wouldn't they be impressed if i modeled a vhf yaggi..  cant even find a cad drawing of em
    I used to have several yagi antennas back in the day...HF and UHF  yes
    awesome rat Ted
    made me think of this from around 1980 or so... why?... I dunno and you probably won't have a clue of what it's about either lol
    well I can watch it on youtube as Bunyip can no doubt but our OS friends will be spared devil
    Oh my issue with the Octohouese was not unticking U wrap
    but I don't give a
    's
    RRRRRRRRRR
    Yagi  not to be confused with Yogi and pic a nic  baskets
    LoRes Octopus Figure
    Pretty rough.  No weightmapping, no constraints, no rotation of joints, but suitable for animating in silly scenes.
    Procedural shaders.
    Free for any use.
    See attached zip.  Let me know if there are problems.
    800 x 600 - 25K
    zip
    zip
    OctoLoDio Zip.zip
    74K
  • Could anybody write a carrara tutorial or a walkthrough on how to model similar hair to Chibi Boy for Genesis?
    edited March 2020
    EDIT:  Sorry, this response was for dynamic hair.
    Hair tutorial and other hair related info
    https://www.daz3d.com/forums/discussion/51604/tutorial-creating-realistic-carrara-hair-for-animations-and-still-renders/p1
    can somehow booleans make a deathstar trench?
    whats a chibi boy?
    smiley
    finding a thread under carrara forum is impossible.
    a few years a go we had a thread about modelling arches
  • DesertDudeDesertDude Posts: 1,239
    There is a discussion and some examples on the 1st page of this thread, not sure if it's the one you remember:
    https://www.daz3d.com/forums/discussion/comment/1314391/#Comment_1314391
    thanks.  but the thread i was remembering we were comparing how to do arches with different tools,  vertex, splines
  • TorquinoxTorquinox Posts: 4,448
    Mystiarra said:
    smiley
    That modeling demo is excellent!
  • Zach WilsonZach Wilson Posts: 92
    edited September 2020
    I'm following this Blender tutorial on modeling a chest https://www.youtube.com/watch?v=ICBP-7x7Chc
    He uses the edge bevel tool to round the courners so I figured I would just use the chamfer tool in Carrara. It works fine except for the top part of the chest corners. I'm not sure how to fix it.
    1920 x 1032 - 332K
    Post edited by Zach Wilson on
  • I would need to see an image of what you mean
  • Here is a capture of his. You can see how the geometry at the top of mine is kinda mangled.
    1304 x 734 - 138K
