Pose preset that turns limits off on necessary dials?
Lissa_xyz
I've got a pose that I've made, which required limits to be turned off on some of the translation dials; however, when after saving the pose and reloading the figure to test it, the figure loads in with limits on, which breaks the pose (I've turned them off on multiple dials).
Is there a way to either a) save the pose to automatically turn limits off on the necessary dials, or b) universally turn limits off? I've tried checking/unchecking Figure > Use Limits with zero success.
PP2014
Post edited by Lissa_xyz on
I have the same problem and I wonder if you found a solution?
Here's a pose that removes all limits for a Genesis figure, so you should be able to craft one for whatever figure you are working with to remove the selected limits...
http://weblog.damageinc3d.net/Weblog/?p=2529
Never mind...
There used to be another way...a global way...or at least I think there was. Don't have 2014...still have 'cut down' intro version from a few years back...Debut 9 or something...before that it was a really old version.
I know that there are poses which removes the limits. But how do I save those? I have no idea about poser prog and I don't want to change morphs. it's just about translation limits. I'm new to the program so I don't understand what to do :'-(
You can't save them, unfortunately; you need to build the pose from the saved figure with a text editor ...
Ah ok, thank you so much for making this clear! Then I will save and make me a note which limits etc. I have to change after loading it :) Thank you again!
As long as you save the figrue pose with the value that is required then when loaded it should bypass the limit in poser or DS as long as the program is set to ignor limits
Just by sheer coincidence I happened to be looking for another post of mine and saw that there were replies here.
I still have the poses I was trying to save out in the form of scenes with just the single figure in the pose. Now that I have a bit more Poser time under my belt I'll have to give it another go.
I thought I'd posted in my initial post what it was for, but the poses are for Squee by Mada (I guess I never considered the fact that it might be different for human vs non-human characters).
