hi i made a new leather coat i hope it came out good so far
this is the pic i was going for   this is the link to this coat https://www.amazon.com/WOMENS-LEATHER-Ladies-Bomber-Leather/dp/B00GM6J07K?th=1
  • That coat looks great and pretty spot on!
  • lasagnamanlasagnaman Posts: 1,001
    thanks so much you think it looks like the pic thats what i was going for i am also working on this one too
    1800 x 1150 - 1M
  • this is the pic i was going for   this is the link to this coat https://www.amazon.com/WOMENS-LEATHER-Ladies-Bomber-Leather/dp/B00GM6J07K?th=1
    Did you intend for the jacket to not pull in at the waist? Also there is something going on with the left collar.
    yeah i did notice that i will fix that thanks for bringing that to my attention
  • that looks good you should sell that lol
  • Hurdy3DHurdy3D Posts: 1,073
    edited December 2019
    looks good. wink
    would I would love to see is:
    •  open morph
    • dForce support
    • morphs for hanging on coat hanger
    • morph for laying on the ground
    • morph for laying on a chair
    • morph for holding in the hand
    • morph for laying on the arm
    • morphs for put that coat on
    Post edited by Hurdy3D on
    the only problem is dont know how to use morphs in other software i wish i did if you can help me walk me through it i would ve glad to add that definitely .i use fit control which is so awesome for clothing.
    what i can do is open the jacket so you have it open and closed ill make 2 coats that way with fit control you can morph it any way you like
    I'm a totally beginner, too.
    But I did in the past some easy adjustment morphs for G8 in Blender.
    Basically you just have to edit the mesh in Blender, export it as an object and load the new object via loadmorpher in DAZ into to object as a new morph.
    Important is, that you don't delete or add new verticies. The base mesh has always to be the same.
    Here's a video. Workflow should be the same for cloth:
    yes, this would also work yes
    did you forget to answer?
    you quoted us, but no text wink
    lol no it works funny on the iphone i’ll respond when i get home from work sorry about that
  • gerster said:
    looks good. wink
    •  open morph
    • dForce support
    dForce will handle most of the morphs much better than morphs would. Using dForce to have a garment drape across a chair or fallen to the floor are really easy.
    gerster said:
    looks good. wink
    •  open morph
    • dForce support
    best would be a morph that prepare the coat with a morph for dForce. I usuale do such stuff with dForce, but it's always a lot of work to prepare the clothing for that.
  • gerster said:
    gerster said:
    looks good. wink
    •  open morph
    • dForce support
    ? How are you prepping a dForce item for simulation? If you mean setting up an animation to do the sim I don't see how a "morph" would eliminate that.
    gerster said:
    gerster said:
    looks good. wink
    •  open morph
    • dForce support
    If you put a a shirt or a jeans in it's original pose into a dForce simulation, to get a piece of cloth which dropped somewhere down I get ususally awefull results. I also move a bones, to get into a fitting position before I run the simulation.
  • I've had to mess with the gravity and air resistance numbers to get a "pants around ankles look right but to get a drape over furniture look the most I've ever had to do was rotate the item around so it doesn't drop quite flat down.
    boy i got to tell you dforce looks so hard to do
    is it difficult.cause i cant figure out how to do it if
    someone can help me that. would be great
    also i don’t know how to take marvelous designer clothing into daz and use dforce with it. does anyone know. thanks
    Post edited by lasagnaman on
