Between "White" Trees
Has anyone else had an issue with a product called "Between Trees"? I bought it a while back and finally wanted to use it but it couldn't find the textures for the trees and some other plants, so it just shows white trees. The product is from Gendragon3D and JeffersonAF.
  • FSMCDesignsFSMCDesigns Posts: 12,845
    I don't have it, but the read me says the textures are located here /Runtime/Textures/Gendragon3D/Between Trees/Plants/ so i guess you could check and see if they are there. If not, then you might be missing part of the d/l
  • For a moment there, I thought you were talking about a 70's prog-rock song.  Okay, back to bed for me!
  • I don't have it, but the read me says the textures are located here /Runtime/Textures/Gendragon3D/Between Trees/Plants/ so i guess you could check and see if they are there. If not, then you might be missing part of the d/l
    I searched the whole runtime and they weren't there. I will try to reinstall.
  • That worked. Thanks FSMCDesigns!
