A couple stupid questions
info_b492a00165info_b492a00165 Posts: 170
edited December 2019 in The Commons
First how do I choose the folder where the data goes?  The prop is already saved in the right folder but there's no option to browse to where the data is?
Also how do you hide the "Morph Loader"?  Just the thing that says Morph Loader.
Post edited by info_b492a00165 on
  • How did you install? If you use DIM, if these are Daz products, everything will be put where it should go. You can't place things wherever you like. Things won't work right. You don't normally need to do anything with the data. What are you hoping to do?
    The Morph Loader is normally not open. Did you try to use it? We need a bit more information.
  • They are DS products but I keep a folder outside of DS where i put everything.  I know in the past the folders show up.  Not sure how they started appearing but they did.
    The morphs are working fine but in the parameters tab under where it says Morphs is "Morph Loader".  I need that to be hidden.
  • Oh I see I just close it before saving and it doesn't load saying that!   Cool!  Thank you.
  • Glad you got it working. It sounds like you have an external directory when you say you keep it outside of DS. That's fine as long as you point to the directory within DS. You also need to maintain the file structure of the directory so that files point to the right place when loading. So that when you load a character, it expects the data folder in the right place for the geometry, the runtime textures folder for the character's materials, etc.
